What am I looking to pay to have pistion rings replaced?
Old Sep 21, 2005 | 01:31 AM
akpsibro's Avatar
Default What am I looking to pay to have pistion rings replaced?
What does the typical job run, cause I really dont want to get ripped off anymore. My machine is a 2001 Foreman 450 ES
Old Sep 21, 2005 | 01:51 AM
RoostinRaptor's Avatar
why do you want to change the piston and rings. it not that old and its a honda you should never have to change the piston and rings on a honda utility unless you realy dont care about it and beet it really bad or you just put a hole lot of miles on her.
Old Sep 21, 2005 | 10:39 AM
akpsibro's Avatar
well i would agree to that but i bought it used and the other day it started to smoke. It smelled like it was buring oil. So that is why I figured it could be the rings or and value gasket leak.
Old Sep 21, 2005 | 11:57 AM
quad2xtreme's Avatar
3 hrs labor plus the cost of the rings and the gasket kit. Will be 4 hrs labor if any valves and seals need replaced. You are looking at $250-550 tops. 550 is assuming you need 2 intake valves and new seals.
Once the shop has the head off, they can tell you if it needs any work.
/Jon
Old Sep 21, 2005 | 01:08 PM
quicksilver's Avatar
if you do it yourself, it's easy. that engine is a pushrod engine, so theres no cam chain or cam timing to worry about if you're just taking the cylinder and head off.
but if you want a shop to do it, have them put new rings in, hone the cylinder LIGHTLY, and put new valve seals in. should be good to go, smoking should be gone for a while.
a better job to do though would be to have the cylinder measured and if necessary, bored to the next size, and buy a piston/ring set for the first overbore and replace the valve guides if there are any and replace the valve seals. then you're good to go for a long time.
Old Sep 21, 2005 | 01:44 PM
Pityocamptes's Avatar
Do these engines have a crank ventilation system? If they do perhaps something failed and it is sucking oil into the engine. Just a thought. Is the smoke blue or black? Black would mean too much fuel and blue would be oil burning.
Old Sep 21, 2005 | 08:15 PM
stuffstuff's Avatar
costed me like 700 for my 400ex with a hour labor took off
Old Sep 21, 2005 | 10:06 PM
96lapiscoupe's Avatar
Woah, I had my spare 400ex motor built with an 11:1 piston, ported head, new valves, and stage 2 Hotcam for $800 including labor and parts.
[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 22, 2005 | 01:36 AM
Can you provide the name of the shop and the phone number?
Thanks,
Jon
Old Sep 22, 2005 | 01:38 PM
He's no longer in business LOL! I wonder why. [img]i/expressions/face-icon-small-wink.gif[/img] He was some old guy that finally retired 2 or 3 years ago. I think he worked on horse and buggy repair before he started on motorcycles and snowmobiles lol ancient.
STLyamwar
Jul 25, 2020 04:44 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
toonces
Jul 28, 2015 01:58 PM
clsharky
Jul 13, 2015 02:07 PM
