LT80 help!
Old Sep 23, 2005 | 12:50 PM
RobW's Avatar
Default LT80 help!
From idle to about half throttle the LT80 runs good, at full throttle it falls on its face and will stall if you don't let off. If you ease it up to full it will make it but not a snap from half to full. Carb and air box are stock, just under 120 pounds on the cyclinder, new plug, stock pipe. Is it too lean? Recently installed a new throttle cable. Should I move the clip down one on the needle to richen it up? Help.
Old Sep 24, 2005 | 09:53 PM
LT80's Avatar
LT80 Expert
Default LT80 help!
NO.
You need to clean the carb.
Main jet is plugged IMO. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 25, 2005 | 04:07 PM
RobW's Avatar
Default LT80 help!
I will give that a shot tomorrow, thanks for the help. Will post the results.
Old Sep 27, 2005 | 07:04 PM
RobW's Avatar
Default LT80 help!
LT80, you were right on, all sorts of junk on and in the jet as well in the float bowl. I did NOT put the black rubber collar back over the jet, seems this could cause problems as part ages. Ho[e thats not a problem. Runs great!! Thank you!!!
Old Sep 27, 2005 | 07:09 PM
hateful's Avatar
Default LT80 help!
yes you dont need that black piece in it gave us a problem for awhile till we fig it out.
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
