up and down
Old Sep 24, 2005 | 09:30 AM
scooter1967's Avatar
Default up and down
when i ride on the tar a little i feel a wobble up and down feeling like the tire isn't round.
whay should i do??
i just bought it and have had it for a week.
sounds like a dumb question......shoulkd a return it?
Old Sep 24, 2005 | 10:18 PM
CATSKINNER's Avatar
Default up and down
That is a common problem with low pressure tires. When my quad sits for a week it feels like it has flat spots on all fours but after I ride it for a while and heat the tires up a little they become round again. Check your pressures and make sure you have the same all the way around. I have found that 4-5 psi is the best for all types of riding conditions.
Good Luck.
Old Sep 24, 2005 | 11:57 PM
Bear4570's Avatar
Default up and down
It's a common problem with any tire, just that with higher dollar car tires this is not so noticable. Try it sometime in -20 degree weather on pavement, you will feel it. On snow or ice not likely as they are usually rough.
Old Jan 11, 2007 | 12:34 AM
yearmax's Avatar
Default up and down
So I have an 01 400 4x4 with the second seat added to the back for my wife. What is the best tire preasure when rideing with her?
Old Jan 11, 2007 | 12:37 AM
squeege's Avatar
Default up and down
I'd follow the print on the tire(if there is any)
Old Jan 11, 2007 | 01:03 AM
Jetmech's Avatar
Default up and down
You are not by chance running tire slime are you? If you are and the road isn't very far from where you park your ATV for a period of time, the slime will settle in the bottom of your tires and it will cause an unbalanced tire situation. Being as your ATV is new, and you live in Minnesota the new slime is still pretty runny and the cold temps would cause it to thicken when its parked. Just a thought!
