Yamaha Bruin 350 4X4 Automatic
Old Sep 25, 2005 | 06:33 PM
keelam's Avatar
Default Yamaha Bruin 350 4X4 Automatic
Is the Yamaha Bruin 350 4X4 Automatic good enough to pull an atv trailer with up to 5 large tree stumps? Is it reliable and how does it hold up with others' in it's class? Any reviews?
Old Sep 25, 2005 | 06:55 PM
paintballbanshee's Avatar
it could pull it, vvery slowly
Old Sep 25, 2005 | 06:58 PM
keelam's Avatar
like how slow?
Old Sep 27, 2005 | 03:26 PM
redmtn's Avatar
Be careful, It can probably pull it in low real slow, but be carefull going down hill, you might jackknife. I jackknifed going down a very steep dirt trail with only about 900 lbs of gravel. I recked the trailer and almost flipped the quad. I think I didn't flip the quad because my quad weighs a ton. The Yamaha Bruin is very light.
Old Sep 27, 2005 | 04:13 PM
hondabuster's Avatar
If youre just gonna be on flat , hard packed ground, itll do fine. But if you try to start out on a hill, or try to stop coming down a hill...its gonna be working hard. Too bad the bruin doesnt have a low range, that would help alot.
Old Sep 29, 2005 | 09:44 AM
LTRACER's Avatar
It'll do fine. I used to pull some very heavy loads of dirt with a TrailBoss 250 and it handled them fine without a low range. Like hondabuster said long hillclimbs might put a hurt on it but short hills and flat ground will be no problem. I don't know of many reviews might try powersportsnetwork.com. My brother in law just bought a 2wd version and he is very happy.
Old Oct 1, 2005 | 06:20 PM
alwaysride's Avatar
IF your doing pulling, i would get the big bear.
Old Oct 2, 2005 | 01:25 AM
keelam's Avatar
"Put an asian in a class, they mess up the curve. Put an asian in a car, they hit the curve"
What are you trying to say fool. What exactly do you mean?
Old Oct 4, 2005 | 12:49 PM
RNTAQUADinNY's Avatar
I've had a Bruin for almost a year now. They are very reliable machines. I pull my 17-foot bowrider around my yard from time to time...you know there's weight there, but they do it. I also pull an ATV Coach (around 475-lbs with kids) with no trouble on all but the steepest trails.
As already stated, flat ground and/or intermittent severe use as described will probably be okay. If you'll be doing this every day and/or having to go up or down substantial hills towing the trailer, I'd strongly recommend something with low range.
Old Oct 4, 2005 | 05:56 PM
keelam's Avatar
Thanks Alot.
2quiker
Mar 22, 2022 08:36 PM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
black_thunder
Sep 6, 2015 04:41 PM
