CV joint
Old Sep 27, 2005 | 10:39 PM
500scrambler4x4's Avatar
Default CV joint
ive got a question that it seems like nobody can answer. is the front yoke/shaft/cv joint/ hub splines and everything the same on a 1992 trail boss as to a 1999 polaris scrambler 500 4x4 any respond would be awesome.
Old Sep 28, 2005 | 08:41 AM
Default CV joint
Anyone????????????????
Old Sep 28, 2005 | 09:41 AM
cornbread2's Avatar
Default CV joint
They are not the same.
Old Sep 29, 2005 | 02:37 PM
THECVMAN's Avatar
Default CV joint
The Trailboss has a cv joint with a key way and the Scrambler has a cv joint with a splines shaft through the hub. Check out www.Polarisind.com or www.partsland.com for some good microfiche on these items. PM if you need any help on these.
Thanks,
Danny
Old Sep 29, 2005 | 07:46 PM
cornbread2's Avatar
Default CV joint
The older ones were always breaking the keys so I assume that is why they changed over to the splines.
Old Sep 30, 2005 | 10:53 AM
THECVMAN's Avatar
Default CV joint
I'm not sure if that was the reason. But the newer ones use an oil bath for the hub assembly. So he shaft are totally different.
89Lt250r
Sep 7, 2015 07:53 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Peter_
Jul 18, 2015 07:06 AM
