Broly´s Project Portugal - Scrambler 440
Old Sep 27, 2005 | 11:30 PM
ArTiC300R's Avatar
Default Broly´s Project Portugal - Scrambler 440
Hi again ...
This time , i am going to show an Polaris Scrambler 440 Big Bore Kit ... a totally project made in Portugal , by a friend of mine ... Broly ( pedro baeta )
To me this is the best Scrambler from Europe , and maybe one of the best in the world ...
All shown in this thread was done and idealized by him ... and no "aaen or hpd" kits were used ...
Estimated Hp : 75
Rev : 8600 rpm
Top Speed : Unknown
Some Specs ...
- Cylinder bored
- Cylinder Ported
- Head Machined
- Wiseco´s Kawasaki KX 500 Piston
- Wiseco´s Kawasaki KX 500 Rod
- Carb Mikuni VM 44
- 2nd Radiator from a Honda CBR 600
- Fully Customized Racing Exhaust
- Adjustable Steering Damper
- Alu Wheels
- DG Front Bumper
- Honda CR 250 VFORCE Reeds
- Nerf Bars
- Anodized Chassis
- New Plastics and Custom Graphics
- ... ( and much more )
Here Some Pics ...
The Start
Chassis
Reeds , Cylinder and Cranck
The Engine
Evolution
Exhaust
Almost There
Final Version
RacingSM Power Convertion
Broly isnt a preparator , or a mechanic , he is an ordinary guy with knowledge ... so he decided to do this Scrambler ...
Thanks by Broly : LuFo ( luis fonseca ) , Gilberto , Tiago ( trail blazer 300r ) ...
Old Sep 28, 2005 | 12:31 PM
CED's Avatar
CED
It seems to be a stroker,is it a 7mm or bigger.I am in the process of helping someone do a stroker right now.The build looks good let us know how it does.
Old Sep 28, 2005 | 01:26 PM
conig's Avatar
Thats a nice build I really like that pipe and silencer. I'm curious it its a stroker as well and if you had to machine the case to make it work.
What kind of tires are those?
Old Sep 28, 2005 | 01:36 PM
Bubba297's Avatar
I am guestimating at exhaust length and cone taper, but I would be willing to bet that maximum power will be made lower than the 8600rpm specified. What rod ratio did he end up with? That rod is A LOT longer than the stock Polaris piece. I hope it doesnt start coming apart too quickly. Dont get me wrong, I like his ideas. Curious on some real dyno testing.
Old Sep 28, 2005 | 01:42 PM
x_scrambler3's Avatar
Im just woundring about the carb setting a an angle like that if it will leak. but It looks great very nice job
Old Sep 28, 2005 | 05:43 PM
duneaholic's Avatar
Be careful on wheelies. It would make a mess of that pretty silencer.[img]i/expressions/face-icon-small-wink.gif[/img]
It's neat to see some different work on a 400. It sure looks good.
Old Sep 28, 2005 | 08:21 PM
scramblered's Avatar
wow it look very nice build mod scrammy,i really doubt it peak at 8600
with a 86mm piston and a 440 motor porting job,or unless you got the crank case ported or the counter balance, i'm doubtful running that without even a girdle kit on it,mine has OVER 75 hp at 76-7700 stock bore
and it is the very reliable limit,but it all depend on the pipe design
whenever you got maybe it is real,but look an awsome build scrammy,
the rear end look pretty nice racer trim.
Old Sep 28, 2005 | 11:18 PM
Troyer23J's Avatar
I dont know about the motor stuff, if its right. It sure does look nice though. I love that thing.
Old Sep 29, 2005 | 11:41 AM
but wait a minute,,if i look carefuly to the motor it sound like
the guy put a major sandwich kit between the jug and the crank case (aluminum spacer),
that alone will RAISE the exhaust port by much and let the engine to rev higher even with a long stroke piston,the vm 44 must flow specefic mixture ratio too,i think i'm loving that project too,i have jugs collecting dust
up here and might be trying one of those thing in the future,but the pipe
lenght still a wonder why doubt for me,pretty sweet engine tough..
Old Sep 29, 2005 | 12:57 PM
ArTiC300R's Avatar
greetings
thks to all comments
conig i think that are hoosier tires ... but i am not sure
bubba297 this bike is on the street´s since 1 year ago with 0 problems
x_scrambler3 i dont know about the carb setting , but what i know is that isnt leaking
scramblered this isn´t the stock bore limit [img]i/expressions/face-icon-small-tongue.gif[/img] , i forgot 1 thing , the crank was also filled with pb to increase torque ... the exhaust was created "hand made" to match all the other mods
Troyer23J so do i
yes ... thats a 12 mm aluminium spacer ... all of this engine was calculated with specific mat calculations ... the spacer was calculated to match with the kx 500 rod , and with the cr 250 reed´s and with the wiseco´s kx 500 forged piston ... all of this was calculated to the engine produce more than 75 hp using normal gas . a specific computer program that was created by broly was used to make some specs like cilynder window angles , exhaust angle , etc ... also the exhaust was angle calculated to produce the 8600 rpm ... combined with the cilynder
sorry for my bad english ...
