Positive Camber correction?
Old Sep 29, 2005 | 12:24 PM
Turn3's Avatar
Default Positive Camber correction?
I was mistaken in an earlier post, I don't seem to have a TOE problem but I do have a slight camber issue. My sons Eton 90 seems to have slight positive camber which worries me because most of his riding/racing will be flat track. I understand the camber will change when the suspension in compressed but my son only weighs 50 pounds and does'nt seem to have much effect on the suspension.
Could lowering the ride height correct this?
Old Sep 29, 2005 | 01:43 PM
BradLoomis's Avatar
Most A Arm manufacture's do this because of motocross jumps. If you have a welder or access to one... you can simply cut off the shockmount on the A Arm and move it slightly out to get the extended ride height height you want. An easy cheap thing to do is to compress the suspension with tie down straps to limit the amount of extended ride height you get. You can actually induce negative camber and even offset the bike for left or right turns depending on the track. Just rember to recheck the toe of the bike because it will probably change a little.
Old Sep 30, 2005 | 04:10 PM
LT80's Avatar
LT80 Expert
Lets get this right,,,The top of the tire is tilted out?
Old Oct 1, 2005 | 10:03 PM
Turn3's Avatar
Yes, the top of the tire points slightly out.
Old Oct 2, 2005 | 02:15 PM
LT80's Avatar
LT80 Expert
I'm wondering if Elka made the shock a tad too long, or maybe you can adjust the shock height.
I'm taking it for granted that you have stock a-arms.
I see minis at the nationals that have this problem, cept WORSE but they have aftermarket arms. I wouldn't let my kid out on a track like that. Like you said, especially for flat track.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
