Limiting top speed of Dinli
Old Sep 30, 2005 | 03:09 AM
retrorocker's Avatar
Default Limiting top speed of Dinli
At one time i saw a post on putting a spacer in the clutch on a Dinli to keep the throttle response but limiting the top speed of the machine. Did a search and can't find it again. Anyone got instructions and place to buy parts, or remember what the name of the post was?
Old Sep 30, 2005 | 11:55 AM
Fastestdad's Avatar
You can pm me your email address I have a pic of a front variator with a spacer/restrictor i can send you. Basically the stock one looks like a wedding band that fits between the two halves of the front variator around the crankshaft not allowing the two halves to squeeze together/shift out to higher gearing. You would also want to make sure you limit the throttle. Winding out the motor in low gear would be bad too. A 50-60 tooth rear sprocket would limit it to 20 mph or so just need a new longer $15 chain too. I'd change the sprocket instead for less mph.
Old Oct 4, 2005 | 11:26 AM
I will PM you fastest dad. It looks like the stock gearing is 13 in front and 32 in the rear. I wouldn't mind giving it a bit more bottom end grunt, but so far the sprockets i have found are a bit spendy. It is likely the speed restricter will be a short term item, just need to do some more teaching. Any suggestions on where to get a sprocket? I am thinking i may not need to go as far as a 50 tooth?
Pehter
Oct 3, 2024 11:00 PM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
ReconBayou
Sep 23, 2015 02:41 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
