LT80 Stator How to Install
Old Oct 1, 2005 | 01:34 AM
ATVDaddy's Avatar
Default LT80 Stator How to Install
I 'm considering installing an upgraded stator from rickystator for my son's LT80 to run lights. Is this a weekend project for a novice mechanic? Any special tools required? Do I need a service manual? Thanks![img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 1, 2005 | 06:37 PM
LT80's Avatar
LT80 Expert
Welcome to the ATV Connection forums. [img]i/expressions/face-icon-small-smile.gif[/img]
You will need a puller to remove the flywheel. You use the 2 holes that the fan bolts are in to pull it. When you use the puller, make sure you are pulling 100% straight. Other than that, it's easy.
At the 9 O'clock position of the stator is where the timing mark is. Just make sure you have the lines in the same place.
Any problems, just come back and ask. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 1, 2005 | 07:24 PM
ATVDaddy's Avatar
LT80 Pro Rider,
Thanks for the help!!! I'm off to order the stator kit and fly wheel puller! My son will have a blast on his first night ride.
Thanks!
Old Oct 1, 2005 | 07:31 PM
LT80's Avatar
LT80 Expert
Good deal! Have a blast!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 7, 2021 | 10:24 AM
Rafe's Avatar
I can't figure out where the stator is on my bike (its no longer charging). Is it on the left side under the front or rear clutch or is it on the right side under the sprocket?
Old Dec 8, 2021 | 03:12 AM
Neither, it is on the right, but on the end of the crankshaft under the plastic cooling shroud. Before assuming it is the stator though I would be making sure wiring is OK and testing stator. With red/white from stator disconnected, put an AC voltmeter between this wire from stator and earth. Run at 5000 rpm. you should get 28v or more. Much lower and stator is not good. If it is OK, and the wiring is good, the regulator is probably faulty.
Old Dec 9, 2021 | 11:44 AM
LT80's Avatar
LT80 Expert
I told him this yesterday.
It's on the right side under the fan.
Ohm it out. 173+/- 20%
ultangler
Nov 30, 2024 01:35 AM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
