My 400 won't start. WHY????
Old Oct 25, 2000 | 05:05 PM
blaster13's Avatar
Well, I was going to go out and ride today, but when I went outside to start it up, it wouldn't start. I checked the plug, same as always, a tad bit rich, but nothing bad(barely noticeable). I tied my quad up to my friends 300ex to try and pop start it. When, I let out the clutch, the motor would rev a little, maybe up to 2500rpm,(Just an estimate)but then it would die when it slowed down. It wouldn't even move when the motor was revving a little. I know it's not a lot of information, but it's all I noticed. Could someone please help me??????? Thanks.
Old Oct 25, 2000 | 05:27 PM
94DGblaster's Avatar
are you getting a spark?
Will the starter work?
Old Oct 25, 2000 | 05:57 PM
Skunky's Avatar
Did you turn on your gas??? maybe your pepcock is cloged or the carb?
Old Oct 25, 2000 | 06:34 PM
blaster13's Avatar
It doesn't seem to be getting enough of a spark. Yes, the gas was on. How do I check the pepcock? Thanks.
Old Oct 25, 2000 | 06:38 PM
400exalltheway's Avatar
can you try to start it or is it not even seem like its on.check the jets and mayne jet one down and then if that doesn't work put a new plug in
Old Oct 25, 2000 | 07:13 PM
SLB300EX's Avatar
Blaster13...my 400ex did the same exact thing..we pulled it to try and start it and everything..nothing worked. Once we changed the plug...it fired right up. My bike is running a bit rich also. I have been thru 2 plugs in a few months. But...I haven't had the first service on it yet, I've only had my 400 a few months.
Change your plug and see if that won't make a difference.
Good luck!!
Old Oct 25, 2000 | 07:14 PM
blaster13's Avatar
It tries to start, but it just won't. It can't really be the jets because I haven't messed around with the carb since I last rode it. I just don't know. Do you think I should just take it to the dealer?
blaster13's Avatar
Old Oct 25, 2000 | 07:15 PM
SLB300EX's Avatar
Blaster13...my 400ex did the same exact thing..we pulled it to try and start it and everything..nothing worked. We honestly didn't think it was getting enough spark either. Once we changed the plug...it fired right up. My bike is running a bit rich also.(it's even stock) I have been thru 2 plugs in a few months. But...I haven't had the first service on it yet. I've only had my 400 a few months.
Good luck!!
Old Oct 25, 2000 | 07:29 PM
blaster13's Avatar
SLB300EX: We seem to be running exactly the same with the plug. I will go out tomorrow and buy a new plug. I really hope the new plug fixes it so I can ride this weekend. Thanks.
