Help, 01 trailblazer no power above half throttle
Old Oct 2, 2005 | 10:20 PM
dirttrack's Avatar
Default Help, 01 trailblazer no power above half throttle
The quad had not been started for a couple of months so the first thing I did was remove and clean the carb but it didn't need it, it was like brand new inside. It starts and idles and runs great up to about half throttle anything above that it just bogs and dies if I keep on the throttle. If I let off it idles and runs fine at low speed. Battery is brand new, air filter is new, fuel filter is clean, spark plug is new, I am thinking not hot enough spark but any help would be greatly appreciated.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Oct 2, 2005 | 10:42 PM
Budman650's Avatar
Sounds as if it's starving for fuel. Does fuel run freely out of the line? Did you pull the main jet out and look thru it? If it was sitting during the hot summer months, probably something still in the carb.
Old Oct 3, 2005 | 03:24 PM
phildogg6's Avatar
sounds to me like a clogged main jet or something like that.
phil
Old Oct 3, 2005 | 07:10 PM
Bubba297's Avatar
Make sure critters or dirt dobbers didnt build up a blockage in the exhaust.
Old Oct 3, 2005 | 10:27 PM
dirttrack's Avatar
Thanks for the input, I took the carb back apart and pulled the jet out and sure enough there was some crap in it. I guess I thought it was so clean when I took it apart the first time I just blew some air through all the passages and nothing seamed clogged. Thanks again for steering me back to what I thought it was to begin with but to stubborn to believe I missed something in there. It runs great again, I guess it did'nt hurt to have a new plug, fuel filter and battery that I don't have to charge up every time I want to ride. Take care and thanks again to Budman650, phildogg6 and Bubba297, you guys ROCK !!![img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 3, 2005 | 11:44 PM
Budman650's Avatar
Glad to help out, been there, done that. Something about those carbs and AZ heat, just doesn't mix.
skinnyr6
Aug 25, 2023 02:18 AM
blpersinger
Jul 15, 2015 09:56 PM
shewshew989
Jul 14, 2015 03:09 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
