400ex hubs wiggle?!
Old Oct 4, 2005 | 08:24 PM
wheelinforlife's Avatar
Default 400ex hubs wiggle?!
My 03 400ex both of my tires wiggle a tad. What is the best way to fix this? And what size bolt is on there for my to tighten it to the axle? One more question for you all is my ex seems not as smooth on the suspension. Should i soften the fronts? They are on the stock position. thanks
Old Oct 4, 2005 | 08:27 PM
RacinJason's Avatar
is the axle nut tight?
it has a cotter pin so even if it is loose the nut may feel tight.
take the axle off and lightly grease the splines in the hubs slide them back on tighten those suckers down...use an impact gun
Old Oct 4, 2005 | 08:57 PM
96lapiscoupe's Avatar
You've got all this stuff in your profile done to your 400ex, and you don't know how to tighten a hub nut?
Trinity 465 Stroker engine which includes modified crank, super light piston, larger sleeve, 12:1 compression, Stage IV exhaust system, full pro port head, high flow valve job, Stage IV camshaft, and spring kit. This engine produces 58 HP...go to trinityracing.com for more info.....
Edlebrock quicksilver carb
ITP Holeshot Tires in the rear
MAXXIS razor tires in the front
ITP beadlock rims
AC racing nerf bars with wheel guards
AC front bumper
AC raving frame skid plate, swing arm skid plate, swing arm skid plate
Renthal handle bars
Scott grips
Moose racing Chrome throttle assembely
Maier hand guards
Magnum CDI rev box
PRM REV scoops
Front and rear shock covers
K+N filter and precharger cover
Lonestar +4 rear Axle
Factory effex seat cover and maching graphics
RUNS ON PUMPED GAS
and trinity racing clutch TextTextText
http://forums.atvconnection.com/Photos.cfm?ID=2871
Old Oct 4, 2005 | 09:13 PM
RacinJason's Avatar
Dont gotta fix em to ride em
blueandy88
Sep 7, 2020 03:11 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
