AHHHHHHHHH!!!!!!!!
Old Oct 13, 2005 | 08:45 PM
MOJAVEalltheway's Avatar
Default AHHHHHHHHH!!!!!!!!
my atc250r isnt running right. its a 1984 atc250r, it had been running fine, then the other day i was driving it and it bogged out and stalled, i tried to start it again but it wouldnt fire, i took the plug out , cleaned it up then tried to start it, it started up very easy and ran fine at idle but when i reved it up it missed and died, ive tried new plugs and it keeps doing it, may this be the air fuel mixture? and how can i fix it
Old Oct 14, 2005 | 12:14 AM
quicksilver's Avatar
check your fuel tank vent, might be building vacuum in the tank.
Old Oct 14, 2005 | 12:22 AM
Bradracer18's Avatar
If it is this it should run good all the time with your fuel cap off.......worth a try......
Old Oct 14, 2005 | 03:35 AM
Torbinx's Avatar
check your actual spark plug wire for a solid connection and no shorts
tyzorg
Mar 28, 2004 09:13 AM
