Exhaust end cap question.
Old Oct 19, 2005 | 11:02 PM
gooch400's Avatar
Default Exhaust end cap question.
I am putting on a billit exhaust end cap. It has a 3 times larger opening than stock. Everything else it stock, but I may be putting on a K&N filter. Will I HAVE to re-jet?
Old Oct 20, 2005 | 12:30 AM
bruteforcebob's Avatar
the end cap wont really make any difference, but the K&N will cause you to have to rejet
Old Oct 20, 2005 | 01:47 AM
rivermud's Avatar
I agree the end cap wont make much difference. Since they come a little on the rich side from the factory you may not have to rejett with the K&N either.
Old Oct 20, 2005 | 10:13 AM
gooch400's Avatar
I thought they were LEAN from the factory to meet emissions.
Thanks for the input. I'll try and run it and check how the plug looks after a ride..
Old Oct 20, 2005 | 10:42 AM
imcarlile's Avatar
Please let me throw my 2 cents in here: I highly recommend a rejet regardless of what you do to your machine. My BF started running bad like it had trash in the carbs, I went ahead and ordered a DynoJet ket and figured while I had the carbs off I would rejet. I have stock air filter and stock exhaust, just from the jet kit the difference is awesome! No more burning the left leg either! Then last week I added the VDI module, from a 10-15 mph punch the bike will stand the front end and walk a wheelie, the power and response is unreal. It's like a totally different bike.
Mike
Old Oct 20, 2005 | 11:22 AM
rivermud's Avatar
Altitude plays a big part on how the quad runs with stock jetting so what might be good for me may not be the best for you. As a general rule they run them a tad rich from the factory because its safer on the engine to run rich. They know about the worst damage a rich mixture will do is foul the plugs and loose performance.
What quad are we talking about anyway??
Old Oct 20, 2005 | 09:31 PM
gooch400's Avatar
Sorry for not listing it. I have a 03 KFX-400.
I live at 500 feet, but do most my riding around 3000-5500 feet. It runs real good with the stock setup, but I am wanting to try and get everything I can out of the stock machine..
Old Oct 22, 2005 | 01:46 AM
rivermud's Avatar
To get the most out of it at 3000-5000' you should be running pretty lean at home. As you go higher the mixture will richen do to less air at higher altitude. So in that case I would not rejet with the K&N. It will not lean it enough to hurt anything and will run better at higher altitude than stock.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
