oil in clutch p650
Old Oct 21, 2005 | 08:23 PM
greenP650's Avatar
Default oil in clutch p650
I have a 2002 prairie 650 and oil is coming from the motor and into the clutch and making the belt slip. Is there a seal that went out?
Old Oct 22, 2005 | 10:46 AM
Al1's Avatar
Al1
Sounds like one of the seals behind the drive or driven clutch,pull the cover and find out which one is bad.You can order seals from ronayers.com they have good prices.
Old Oct 22, 2005 | 08:18 PM
hitman1970's Avatar
Al1 is right but while your tearing into it look to see why the seal failed. Bad seal, bad bearing or blocked case vent ect.. Just a hint from past experiences I have had.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 23, 2005 | 12:23 AM
greenP650's Avatar
I just got the recall done, swingarm bushings, and rear axle bearings put in by my local dealer could they have done anything to make my seal go out. I got my bike back tuesday seals wentout wednesday. Makes me wonder
Old Oct 23, 2005 | 10:43 AM
LTRACER's Avatar
My brand new 05 p700 did this as soon as I took off on the first ride. I couldn't believe the dealer couldn't tell the belt was slipping when they loaded it on the trailer. I carried it back the next day and they fixed it in about an hour, said some o-ring was leaking oil on the belt so they replaced it, no more problems so far. Hope yours is as easy to fix.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
