500 auto-revs high- no go
2004 500 auto got carb dialed in went for ride, playing on larg pils of dirt near by and all of a sudden it just quit pulling high-low-reverse!!!! motor revs high bou no go. got it back to shop ,removed clutch cover and clutches and have discovered that the output shaft from the motor has a one way directional sprag inside. started motor and held shaft with my hand and reved the motor half way up and could hold shaft still.!.! need info or diagram to inside of clutch housing please
good posibality...................
did some web searching, found a web sight that had micro fiche. www.brownsleisureworld.com/Parts/Images have found out that the drive clutch for the belt is driven by a centrificle clutch off the crank(behind engine/trans housing) like the auto clutch on a manual shift model. i am checking with dealer for prices on replacement shoes as well as checking with erlandson performance for better quality aftermarket ones
wish me luck
wish me luck
