Clutch how to? know how?
Old Oct 23, 2005 | 02:00 PM
dczys's Avatar
Default Clutch how to? know how?
this is a -95 polaris 300 4x4
how do u swop out the clutch spring, and what clutch do you normally swap the spring in, or both? how hard is it to do? and is there any special tools needed? u may be able to tell i have little knowledge working on a clutch..
thanks
Old Oct 23, 2005 | 10:31 PM
ftwflh's Avatar
You can change springs with normal tools.But if you can say what pipe you are running we can help you more with the clutching.
Old Oct 24, 2005 | 12:00 AM
dczys's Avatar
ok well heres the deal,, old muffler rusted out a bit,, soooo took a glasspack and cut it to the same lenght, next welded a plate over the outlet. then cut a small hole near the end of the muffler and welded a downspout on it to be the new outlet. looks exactly stock.. but except it pretty much free flowing straight through exhaust, then rejtted it.. went from a 160 main to a 165.. seems to work good,, any sugestions with that setup? and know what to do with clutching>?
thanks
Old Oct 24, 2005 | 12:23 AM
ftwflh's Avatar
Put a white polaris primay spring in and go with it.
Old Oct 24, 2005 | 11:33 AM
dczys's Avatar
whats in there stock right now? what kind of differnce/improvements would this make? and where can i find one cheap? thanks a ton for listening to my dumb questions...
Old Oct 24, 2005 | 06:27 PM
ftwflh's Avatar
You should have a blue/green spring now.Best bet is to spend $20 at a dealer and get a stock primary spring for a 2000 400 Scrambler.It is what is called a white but looks plain with white paint on one end.
Old Oct 24, 2005 | 08:46 PM
dczys's Avatar
what improvments will this make and also, after i take of the housing to the clutches whats the simplest way to swap out the spring?
thanks a ton...
Old Oct 25, 2005 | 07:56 AM
ftwflh's Avatar
thanks a ton...
Take the center bolt out then the 6 smaller bolts change spring put parts back together.
Old Oct 26, 2005 | 02:36 PM
modquad's Avatar
Aaen performancee has a very informative clutch info/tuning manual. Inexpensive, and a very good read. [img]i/expressions/face-icon-small-smile.gif[/img]
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
