Starter on LT80
Old Oct 23, 2005 | 04:39 PM
russel2's Avatar
Default starter on lt80
My kids have an LT80. I just picked up the wiring diagram from my local dealer. When you push the starter button you can hear the starter turn with a scream. If you pull start you can get compression when it grabs. it is an '87. Electrically I have power going to the regulator on the red wire and nothing on the white with red stipe. There is no power going to the ignition coil or to the magneto. Do I need to replace the regulator and the ignition coil or is there something else wrong that I am missing. Thanks.
Old Oct 23, 2005 | 08:42 PM
LT80's Avatar
LT80 Expert
Default Starter on LT80
The starter is spinning but it isn't engaging to turn the motor?
Old Oct 23, 2005 | 09:37 PM
russel2's Avatar
It doesn't seem like it is engaging the motor, and when I pull start still does not spark and the regulator does not have power coming out of it.
Old Oct 24, 2005 | 10:55 AM
LT80's Avatar
LT80 Expert
LMAO!! You cannot pull start a CVT machine. [img]i/expressions/face-icon-small-smile.gif[/img] I was hoping you meant with a pull starter.
Your problem is with the starter. It isn't moving out to engage the starter gear when activated.
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
Jackg17
Sep 26, 2015 09:30 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
