330EX cooling
Old Oct 28, 2000 | 03:42 PM
cstark's Avatar
I am installing a TC330 kit on my EX as we speak. My engine builder(TC Racing)told me that it was not nessesary too install an oil cooler with this kit, as long as I run a heavy weight synthetic oil. But I am still alittle worried. What are you doing with your built engines?
Old Oct 28, 2000 | 04:35 PM
94DGblaster's Avatar
what made you go with the 330..?
just wondering..
Old Oct 28, 2000 | 05:01 PM
400exalltheway's Avatar
well i think if you ran a heavy weight oil you would be ok, but i think it would help alot if you put a oil cool on it also
Old Oct 28, 2000 | 06:50 PM
cstark's Avatar
330 is the largest you can go without modifying the crank. A properly build 330 engine will put 35HP at the rear wheels(stock is 17). For my racing needs(MX and XC), it should do nicely.
From what I have seen, playing with the crank(stroking), is like playing with fire.
Old Oct 28, 2000 | 08:50 PM
i just wondered. You seemed really happy with the power you had now.
More is always better.
What is the cost of a complete 330? I'm still looking for motor mods.. lol
Old Oct 28, 2000 | 09:03 PM
cstark's Avatar
Parts start at about $1000. Plus the cost of a pipe and labor too have it installed(unless you can do it yourself).
I did like the power I had before. But I was going too rebuild the top end this winter anyway. I just decided too buy alittle bigger piston and a larger sleeve.
Old Oct 29, 2000 | 01:38 AM
AL300EX's Avatar
my 330 kit was only 400 dollars, but i did the work myself though. As for cooling, mine runs just a little hotter than it did when it was stock. I use semi-synthetic 4-stoke oil and it works great,just dont use regular automotive oil. I dont like 100% synthetic oil at all, it just does,nt stay on anything in your engine if you have stored it for a while, making cold starts even worse. my 330 dyno'd yesterday at 29.28 hp, i hope with a little more tuning i can get it up a little higher, but 29 is fine for now, Good luck with yours
Old Oct 29, 2000 | 09:10 AM
AL300EX's Avatar
by the way do you send your whole engine to T.C. Racing? I was just wondering how long it took them to do the engine work?
Old Oct 29, 2000 | 11:33 AM
cstark's Avatar
A complete 330 motor cost more than $400 dollars.
piston/sleeve - $295
camshaft - $150
valve springs - $ 90
carb - $175
head work - $200
CDI - $ 90
pipe of your choice - ???
(all dollar estimates vary between different engine builders)
Mine will dyno right around 35rwHP when it is finished.
I bought all of the parts from TC and installed most of them myself. My dealer did the boring and pressed the sleeve in for me.
Old Oct 29, 2000 | 01:27 PM
powroll 330 kit is like 295
without cam, and valve springs.
They told me no head work was needed. Just install the sleeve and piston.
