how do I get my throttle cable in this pwk 39? scrammy
Old Oct 23, 2005 | 11:46 PM
ScramaDamaDingDong's Avatar
Default how do I get my throttle cable in this pwk 39? scrammy
I'm getting pretty close to being finished with my rebuild on my scrammy, but I can't get the throttle cable into the pwk carb. what's the trick?
Old Oct 23, 2005 | 11:59 PM
Whitedog's Avatar
Can ya give more detail? Are you using a new aftermarket cable?
Old Oct 24, 2005 | 12:12 AM
RickRitter's Avatar
You may have to file a bit on cable . Phone me I can help .
Rick
Old Oct 24, 2005 | 01:06 AM
EAB's Avatar
EAB
^^^Thats what I had to do. Just make it fit.
Old Oct 24, 2005 | 10:56 AM
conig's Avatar
I cut the bung off the end and threaded mine through. my dealer had motion pro barrels that could be clamped into place. I also learned a piece of the metal from a but connector works well also.
Old Oct 24, 2005 | 01:11 PM
just using the same old stock cable
Old Oct 24, 2005 | 01:17 PM
conig's Avatar
I got rid of the stock cable, the reaction got really slow and after about 3 months of no oil injection my throttle stuck and I went into my fence. I'm presently using a z400 clutch cable I fabbed up to work.
I really have to for that reason suggest using a new cable. I did get the stocker to fit the PWK however by grinding the end of it down anough to press into the nut type thing that attaches to the slide. grind it alittle press it in place with a set of pliers. then screw it onto the slide and after that install the spring be threading it around the cable. I found this to be the easiest way. I however take no responsibility if you almost go through privacy fence like I did. (small yard)
Old Oct 24, 2005 | 02:06 PM
conig's Avatar
one other thing on the stock cable, there is a cylinder section at the bottom a space and a ball section towards the top. the ball section is what I had to grind down actually off very carefully. good luck.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
Brandon400
Sep 7, 2015 12:20 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
