Trailblazer brake problems
Old Oct 24, 2005 | 02:47 AM
flyboeing's Avatar
Default Trailblazer brake problems
Alright, spent the day swaping out a new tranny, start putting stuff back together and its all going well excpet....
When i was taking the back brake caliper apart, I accidently split it, with the 2 allen bolts and the 3rd in the pivot. I got all the parts put it together just like the parts diagram. I bleed the system all the way through so that there was new (clear) fluid coming out. The rear caliper works great with the brake lever on the handlebars. It does nothing with the foot lever, has no compression/resistance. The lever compressess the plunger in the caliper, it just doesn't clamp down. Is there somewhere else I need to bleed it, or is there some special o-ring or plunger not on the parts diagram, it wasn't great, just the Polarais OEM website. The quad is not unusable because the brake work great, especially with all new fluid, but isolated back brakes would be nice this weekend at the dunes....
thanks in advance for any help.
Old Oct 24, 2005 | 07:57 AM
ftwflh's Avatar
What year of Trailblazer do you have?On the newer ones you have to bleed the rear master cylinder seperatly.But most just let it go because they dont work anyways.
Old Oct 24, 2005 | 11:33 AM
flyboeing's Avatar
its a 97 250, but I did bleed it a the master cylinder, I even left those 2 bolts loose(a little) untill fluid started coming out around the gasket thinking maybe that would prime the plunger in the master cylinder. No luck.
thanks
Old Oct 24, 2005 | 06:30 PM
ftwflh's Avatar
OK you have a non concentric one so you will need to take up the slack at the rear brake by loosining the jam nut and tighten the bolt in until you get some peddle but not enough to lock up the brake.
Old Dec 3, 2005 | 01:32 PM
JjEjFjf's Avatar
What do you have do on the "concentric" one? My son has a 99 and it has the exact same problem.
Old Dec 3, 2005 | 02:29 PM
ftwflh's Avatar
THe concentric modles have a brake on the axle non concentric is on the transmision.Ont he 99 try bleeding it with the resivoir full but the cap and plug off(keep it full)
Old Dec 3, 2005 | 11:52 PM
JjEjFjf's Avatar
Thanks
Old Dec 4, 2005 | 10:21 AM
Mudcruiser250's Avatar
my 2004 had the same problem ever scince we got it. we took it to the dealer and all he did was bleed the master cylinder and now it has alot of stoping power at the rear wheels
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
timster911
Jul 13, 2015 01:57 PM
