2006 polaris 800 pulls to right
Old Oct 26, 2005 | 01:24 AM
reddog1495's Avatar
Default 2006 polaris 800 pulls to right
I bought a new 800 sportsman and it pulls to the right so bad the front tires are starting to wear with 77 miles on it. Only been ridden 2 times and is back at the dealer that cant figure what is wrong with it. Was wondering if anyone has had simular problems and if I can make the dealer give me another 4 wheeler. Thank You.
Old Oct 26, 2005 | 02:08 AM
jimmypsp700's Avatar
They should be able to fix it, sounds like a bad alignment, tie rod or CV joint.
Dont let them off the hook until its fixed.
You may need to contact polaris or take it to another dealer if they are incompitent.
Jim
Old Oct 26, 2005 | 04:18 AM
polarisbear500's Avatar
kinda sounds like what happened to mine and it wasnt realeasing from AWD on the right side. usually due to lack of hub fluid. dont know if that is the problem, but mine did that. good luck
Old Oct 26, 2005 | 05:12 AM
twoblackbelt's Avatar
RYFOM, too.
Sounds like a lemon not releasing from AWD to me, too. If it does not release after being run in reverse in 2WD and crancking the bars fully from full right-to-left something is amiss.
And I also agree, do NOT let the dealer give it back unless it is right.
An ATV that badly out of alignment from the facory would be VERY odd.
Someone making 7 bucks an hour assembling new quads, however,
could get one that bad out of whack.
D
Old Oct 26, 2005 | 06:37 AM
may sound kinda dumb, but what is RYFOM?
Old Oct 26, 2005 | 11:28 AM
mtpockets's Avatar
measure the diameter of the tires. i owned a Predator that pulled hard-right and my Dealer found the diameter of the REAR tires differed even though the sidewall writing read that they were the same.
let us know what they find.
~MT
Old Oct 26, 2005 | 11:31 AM
mtpockets's Avatar
LMAO Polarisbear500! i was wondering the same thing! LOL!
how 'bout it twoblackbelt?
~MT[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 29, 2005 | 11:32 PM
anyone know what RYFOM means? thanks
Old Oct 29, 2005 | 11:56 PM
Nuse's Avatar
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">my 05 500 ho also does this some times after being in AWD some times I just go in Reverse to get it to stop it seems to work my hub oil is full</SPAN>
Old Oct 30, 2005 | 01:46 AM
03TRX300ex's Avatar
did you still hae the problem?
