500 HO hard startin
Old Oct 26, 2005 | 12:01 PM
TheRedRhino's Avatar
Default 500 HO hard startin
Has anyone had 500 HO having a hard time starting?
So far the battery is good, choke is set right, idle is set correct, air filter is new, the throttle cable has been replaced.
Mac The Red Rhino
05 500 HO Red
Temp Gauge
hot grips and thumb warmer
warn winch
3 way headlight
override switch
bumpers frt & rr
choko rear box
hand guards
Old Oct 26, 2005 | 04:10 PM
hotrod1969's Avatar
Try adjusting the throttle cable. There is an adjustment for the throttle control. If it is too slack, it will not let the bike run.
Old Oct 27, 2005 | 10:30 AM
Thanks for the info, but that has been done time and time.
Mac
Old Oct 27, 2005 | 03:44 PM
fubar's Avatar
Could it be that you got a bad batch of gas?? Maybe some water in it? How does she run once you get it going?
Old Oct 27, 2005 | 06:47 PM
cornbread2's Avatar
Are the valves tight?
Old Oct 30, 2005 | 09:07 AM
Well here's an update from the dealer. He called the mfg rep. The tech told him to check the compression release spring or worn cam lobes. They have had some machines with these for some of the hard starting.
Since the carb is clean, vents lines are fine, filters are clean or new, gas is good and the battery is fine.
Plus the machine does start by pull rope easier than by electric starter.
Mac
Old Nov 22, 2005 | 11:19 AM
Sorry that I haven't responded to the corrected solution on the hard starting problem.
The probelm was the compression spring was broken and replaced. Now the machine is like new again. The carb bowl did have crude in it. So, with a standard tune up and carb cleaning I'am back in business. Thanks for all of you who responded.
Mac The Red Rhino
Member of the Iron Range Riders
05 Red Sportsman HO
warn winch
hot grips & thumb warmer
temp gauge
Reverse override switch
headlight conversion
Choko rear box
Red 60 inch Cycle Country Plow
19 inch lock & ride windsheild
mirror
handlebar gaunlets
Old Nov 22, 2005 | 09:05 PM
Temper50's Avatar
Nevermind I see you got it fixed.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Whitelx1
Oct 2, 2015 10:55 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
