raptor sputter on decel.
Newbie here. Just bought a 01 Raptor stock. Upon letting of throttle (decel) have a sputter. Cleaned carb already. Plug new. Valves adjusted. Set mixture screws as Clymer manual says. 3 out on left and 2 on right. Should i come out more on them or turn in? Suggestions? thanks
popping on the decel is usually a lean idle circuit
try backing the 2 out a 1/4 turn at a time and see if it helps,,,leave 3 alone
if that doesnt work,,,,go to a size 25 pilots (stock is 22.5)
also,,,be sure you have no exhaust leaks at the head
Alex Rodak
Sep 12, 2015 09:39 AM
