deglazing clutches?
Old Oct 29, 2005 | 03:48 PM
dczys's Avatar
Default deglazing clutches?
is there a quik way to deglaze the the clutches w/o removing them?
How much of a differnce does this make, and how do you know if it needs to be done?
Thanks
Old Oct 29, 2005 | 04:07 PM
Alpine2's Avatar
brake cleaner
Old Oct 29, 2005 | 09:49 PM
2manytoys's Avatar
There is no deglazing the clutches. Just cleaning them. The clutches are supposed to be smooth and shiny. The belt will also be sort of shiny to. If you clean the clutches you should use soap and water or a non chlorinated brake clean.
Old Oct 29, 2005 | 10:06 PM
Andre's Avatar
The PVT gurus say to use warm soapy water and Scotch Bright pads. Since yours is a 95 it can't hurt to take the clutch cover off and clean the whole deal up. Actual glazing on the clutch sheaves will allow the belt to slip easier, so a microscopic scuffing to remove build-up on the sheave faces will give better belt grab.
Old Oct 29, 2005 | 10:35 PM
powerslider's Avatar
Scotch Brite pads work very well, I buff them at every cleaning 500 miles or so....
Old Oct 29, 2005 | 10:49 PM
Whitedog's Avatar
I use acetone on mine
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
