no nuttin newby needs help
Old Oct 30, 2005 | 10:31 AM
icepique's Avatar
Default no nuttin newby needs help
just bot 1987 250 es/r 2x for simple ranch use. seems to run well but chain comes off constantly. doesn't seem that loose. what might be causes?
Old Oct 30, 2005 | 10:40 AM
Gix's Avatar
Gix
bent sprocket would do that.. can the axle be not centered on those things like on a bike? where maybe the right side is further up than the left? I dunno.
so what's an es/r?
Old Oct 30, 2005 | 10:49 AM
icepique's Avatar
es/r is simply the particular model i am assuming as that is what is written in the side of it. "250 trail boss es/r". rear sprocket seems true doesn't seem out of line if it is how would it be corrected?
Old Oct 30, 2005 | 10:59 AM
Gix's Avatar
Gix
what about the countershaft sprocket, er, the front sprocket... not sure how the trailboss is, I think it's the same as my 87 cyclone. Really, the only things I can think of are bent sprockets (or output/countershaft)or a bad chain. Maybe the chain is overly loose... or got bad links in it and it binds as it's trying to go around the sprockets.
Old Oct 30, 2005 | 11:07 AM
icepique's Avatar
hmmm..... inspected chain seems ok but i don't know what to look for does not seem to be same spot on chain or sprocket. comes off rear sprocket to left side every time
Old Oct 30, 2005 | 04:45 PM
ftwflh's Avatar
Most the time when you keep loosing a chain it is due to bad axle carrier bearings or swing arm bushings or both.
Old Oct 30, 2005 | 04:51 PM
icepique's Avatar
and how would i determineif these components were a problem
Old Oct 30, 2005 | 06:35 PM
ftwflh's Avatar
Jack it up off the ground and start shaking the rear end and look for movment
Old Oct 30, 2005 | 08:08 PM
elkbow's Avatar
the bearings could be the problem, could also be worn sprockets and possibly a bad chain that is binding....are you sure it is tight enough...because a loose chain will be the most likely problem and easiest to fix....
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
kampswas
Sep 23, 2015 05:05 AM
Hack714
Sep 20, 2015 05:54 PM
that1redhead
Sep 8, 2015 11:47 AM
