need help with recoil
Old Oct 30, 2005 | 04:01 PM
ninjasteps's Avatar
Default Almost There
Working on an Polaris Trailblazer, i need to get in past the right side case that the recoil wheel rests on. Ive taken off the thin black metal that covers the recoil, i have taken out the six or so bolts out of the case, but it wont budge. My question is, does the recoil wheel have to come off before the case will come off? Or is that the case is just sealed tight enough that im going to have to do more than tug on it? Any help will be appreciated.
Old Oct 30, 2005 | 05:11 PM
ninjasteps's Avatar
If the recoil wheel needs to come off, how do i do this?
Old Oct 31, 2005 | 09:41 PM
Bradracer18's Avatar
I guess I don't understand where you are talking.......are you talking about the pull start??
Old Nov 1, 2005 | 02:17 AM
ninjasteps's Avatar
Ya, the pull start, the rope is off of it, so all that is left there on the side of the case is the plastic wheel that the rope goes on. So im trying to get on past all of this you know, to expose the inside. The thing is i dont know if that plastic wheel has to come off to get the case off, the reason i am wondering in the first place is that side case wont budge for me, and it seems i have all the bolts out of it. But to get right down to it, if the plastic wheel has to come off for it to release ,how do i do this, if it doesnt have to come off, theres alittle trick im unaware of, to break the seal on that case.
Old Nov 1, 2005 | 01:11 PM
Boy.....I don't know for sure......I thought it just came off......change your title name to recoil help(or something similar)......and people should help ya out.......and keep the topic towards the top of the posts, to draw attention.
Old Nov 1, 2005 | 04:13 PM
ninjasteps's Avatar
alright, thanks man
Old Nov 1, 2005 | 10:08 PM
ninjasteps's Avatar
Default need help with recoil
After changing the title name, i typed this to scooch back up towards the top, to see if the new title would help me find someone to give me advice. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 2, 2005 | 12:52 AM
Charlie's Avatar
The recoil cover is sealed with a loctite sealant that needs a good rap to get it to release. Then you can access the spring and the special bolt that holds the pulley. This special bolt holds the pawl and its return spring and is square shaped. Hold this in the corner of a vise or put a large crecent wrench in the vise to hold it.remove the pulley counter clock wise. Make sure the alignment tabs are together on reassembly.
Hope ya figure it out, Charlie
Old Nov 2, 2005 | 01:16 AM
ninjasteps's Avatar
Very grateful for the information Charlie
Dammar
Apr 20, 2016 06:03 AM
WesTech
11
Aug 11, 2015 07:55 AM
Desimation2k8
Jul 17, 2015 12:37 AM
fullthrottle
Jul 10, 2001 07:52 AM
