lt80 chain
Old Oct 30, 2005 | 08:03 PM
russel2's Avatar
Default lt80 chain
I'm trying to understand what was said in other forums. I want to adjust the chain on the lt80, but i do not want to put a roller on it. I would like to increase the speed for my 12yr old son who likes to ride on trails with me and can't keep up with daddy's ltz-400. I have a stock gearing 10x22. If I increase the main drive to a 15 tooth and add link to the chain this will tighten the chain plus give it a little more speed? And thanks Lt80 for the starter problem. I pulled the pull starter off cleaned it now it works fine. I finally said screw it with the electric stater. If I had to pull start an engine when was little my kids can do the same.
Old Oct 31, 2005 | 07:12 PM
LT80's Avatar
LT80 Expert
Default lt80 chain
Going up in front sprocket size will help get you where you want to be, but going to a 15 is dramatic. [img]i/expressions/face-icon-small-smile.gif[/img] It'll cause a headache I'm tellin ya. [img]i/expressions/face-icon-small-happy.gif[/img] LOL
You "MAY" be able to use a 11 tooth (yam blaster sprocket) and use the existing chain. Bigger than 11 would require a different chain. Regardless, going up 2-3 teeth in the front is all that is recommended.
FYI:: I go to 428 size sprockets (you have 520 now) and use #40 go-kart chain. The #40 chain has 1/2 links available to make things much easyer.
If you go that route, you will want a 13 or 14 front and a 26 rear.
Old Dec 26, 2005 | 06:18 PM
Quad4Fun's Avatar
Default lt80 chain
Hey Jack,
I'm waiting for my 428 sprockets to get here (26 Rear, 13,14 front),
but might not be in time for our next race.
I have a couple combos of the 520 sprockets.
I have Rear 20,21,22,23........Front 10,12,13
So I have a question on gearing.
<u>According to the chart below:</u>
22x10 (stock) = 2.20
22x11 = 2.0 as has been recommended.
Would these two combos be equal??????
26x13 = 2.0
20x10 = 2.0
Would these two combos be close??????
26x14 = 1.86
22x12 = 1.83
I'm not sure if the sizes matter, or the just the ratios ??????????????
If not, I'll just go buy the Blaster 11 tooth and try that.
THANKS
Rebel Gears - Gear ratio chart
Old Dec 26, 2005 | 10:14 PM
LT80's Avatar
LT80 Expert
Default lt80 chain
You are thinking correctly.
Use the 520 chain/sprockets for now. [img]i/expressions/face-icon-small-smile.gif[/img]
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
