idle trouble
Old Oct 30, 2005 | 11:30 PM
smatpak's Avatar
Default idle trouble
on cold (55 degrees and below) days i can t keep my 03 sportsman 500 ho idling. this happens at a cold start and any other time i need to start er up, even after its warmed up. the only way i can keep it going is there a little play in the throttle lever. if i just touch the throttle and move it (about 1/16") that takes care of the problem but its a real pain in the *** when trying to do yard work or hunt. im not real familiar with atv maintenance yet, only been at it for about 2.5 years now and the 5 hunny is about that old and just recently things started coming up.appreciate any help, thanks
Old Oct 31, 2005 | 12:25 AM
scramblerXrated's Avatar
sounds like you need to adjust your idle setting. or adjust throttle cable, or both. look in your repair manual for proper procedure.
X
Old Oct 31, 2005 | 01:55 AM
RickRitter's Avatar
Yep .. Thats right I think .. It is the throttle over ride killing the igniton I bet ... Pop the top off the throttle housing on the handle bars . Watch the contact points and notice how the motor dies . Hard to explain but once you see it happen it will make sence .
Rick Ritter
Nosniborpapa
Sep 12, 2015 05:54 PM
Jaymc
Sep 11, 2015 07:45 AM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
