Oil and Air filters for Brute Force 750
What do you guys use for the oil and air filters in your Brutes. I see that a lot of you use "Twin Air" air filters. Reasons??? Also, i see that K&N has an air filter out for the brute now, anyone try those yet? As far as oil filters I have no idea, is there a better aftermarket oil filter than the OEM ones, I will probably be running Amsoil full synthetic V-twin oil. Thanks
The Main reason for using a twin air filter is that it is a foam filter that is oiled. I keeps dirt and water out 100% better than a K&N filter does. as for a oil filter I just use a WIX filter from Oreillys dont remember the #off hand. for the sport quads and sand draggers the K&N is the perfect air filter, but dont get it near water it wont hold out water at all, also usually you end up having to rejet with them. Twin air is a Great replacement and its only like 18 dollars. hope this helps ya out.
Bob
Bob
