02 700 fr driveshaft pulled out of cv joint - again!
Old Oct 31, 2005 | 03:04 PM
Saskie's Avatar
Default 02 700 fr driveshaft pulled out of cv joint - again!
I am having trouble figuring out why my front driveshaft has pulled out of the cv joint for the second time. I have no idea why it happened the first time. I was pulling a hunting trailer through some mud holes, and realized I didn't have awd. I got off and looked to see the drive shaft laying in the mud. I attributed the failure to the front wheels being toed out too much?(I'm guessing,,, could too much of a steering angle, or too sharp of a turn, cause the shaft to come out of the cv joint?) I bought a new assembled shaft from Polaris and installed it.(old shaft was mushroomed) I toed in the wheels as per the service manual.(to me they are running straight in line with the rear wheels) I drove in a couple of quad rally's, tested out the awd, and everything seemed to be fine. Went hunting again, and the first mud hole I hit, the drive shaft popped out of the cv joint, and tore the boot off. This time I noticed that I had left the cotter pin off of the ball joint nut, and the ball joint castle nut had back off created a little more play in the wheel. Could this have been enough to cause the driveshaft to come out of the cv joint? I am running stock tires, with no lift kit. The A frame is not bent or damaged. The hub nut was tighted to spec, and the front wheel bearings are in good shape. What else could I be looking for? It is like the shaft is too short or something. I know there are 2 different shafts for the 02 700, but I have checked twice with my dealer to ensure I have the right shaft.
Any suggestions would be greatly appreciated. I have been searching quite a bit, but haven't found any similar posts.
Old Oct 31, 2005 | 07:28 PM
POLARISSportsman500HO's Avatar
if the castle nut back off a bit that could be the problem. Did you have the cotter pin in place snug with the nut. If you did that nut shouldn't go anywhere.
Ty
Old Oct 31, 2005 | 08:15 PM
Saskie's Avatar
I had the castle nut tightened, then forgot to put the cotter pin back in,,,, my fault. I must have taken a while for the castle nut to work loose. I broke the original cotter pin, and didn't have a new one handy. I just forgot to put a new one back in.
In my mind,,, that's what caused the second drive shaft to pull out,,,, but I just wanted some second opinions.... Thanks for the reply.
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
metal249
Jul 28, 2015 09:35 AM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
