04 700 EFI Which Clutch Kit Guys?
Old Nov 1, 2005 | 03:34 PM
bugmanjr3351's Avatar
Default 04 700 EFI Which Clutch Kit Guys?
Dalton, Heel Clicker, Outlaw Extreme, EPI, Etc.!!![img]i/expressions/face-icon-small-confused.gif[/img]
Wow, Big selection!
I have 27" Tires, Stock Everything Else other than Lift.. Im looking for insane low end, I dont care about top end at all. I"m looking for power right off the stop and good belt engagement. You guys have and direct experience with these kits?
Any Info. Would Be Great.
bUg
Old Nov 1, 2005 | 06:16 PM
ppope's Avatar
Don't waste your money on anything but heelclicker! Trust me I did and end result was the heelclicker. I have a dalton and epi I can sell you. None compare to the heelclicker!!!!
Old Nov 1, 2005 | 07:59 PM
SPORTSMAN70003's Avatar
I have the heelcliker and I like it because your able to tune it to your riding style. I did some time runs between stock and the heelclicker and the times were pretty much the same. If you want some serious low end put a 800 primary on it.
Old Nov 1, 2005 | 09:15 PM
ppope's Avatar
Sportsman70003,
Can you tell a difference in yours with the heel clicker and without?
Old Nov 1, 2005 | 10:07 PM
It fills like it pulls harder with the heelclicker.
Old Nov 1, 2005 | 10:46 PM
bigred500's Avatar
That is the feedback I got also. Everyone says the HeelClicker is the best, and from the little bit of research I did, they seem right. Although, I have changed my mind and decided to go with the 800 primary. I have a brand new, never out of the box HeelClicker kit that I'll sale you if you want to go that route. I just bought it two weeks ago, PM me if you want to discuss it.
Old Nov 2, 2005 | 12:02 PM
Speedwerx's Avatar
For what you are looking for the 800 primary would be the best performance wise the 04 700 isn't bad in stk. you can make it a little better by changing springs and weight and helix but the 800 pri with proper weight and spring would be better. larger tires wil make a differance too do you know how much heavier they are than stk. ?
Old Nov 2, 2005 | 01:58 PM
Where is the best place to get the primary and what is the general cost of it.
What else do you need to go with the primary both springs and weights?
Thanks guys
Old Nov 2, 2005 | 04:09 PM
I got mine from the stealer $349.99.
Old Nov 2, 2005 | 05:02 PM
Speedwerx's Avatar
You can get the primary form any polaris dealer but you are going to have to double check your clutch alignment once it's installed too. The primary is normally 349.00 and a primary spring from us is 27.95 and weights are about 80-90.00 we can install them.
