BIG PROBLEM!!!!!!!!!!
Old Nov 2, 2005 | 02:05 AM
dczys's Avatar
Default BIG PROBLEM!!!!!!!!!!
OK dont ask me how, bu i got a small socket wedged in the back of my primary clutch. there is no way no how to get it out, as far as i know. any ideas to get this damn clutch off now? and what would happen if i just left it as is w/o putting the cenetr bolt back in? any ideas PLEEEEEEEEEZ help..
Thank you
Old Nov 2, 2005 | 02:12 AM
jimmypsp700's Avatar
DO NoT run it w/o the bolt on or that socket wedged in there. You may bend somrething or throw it out or balance.
You need to remove the clutch if you cant get it out.
You may need a puller.
Jim
Old Nov 2, 2005 | 09:11 AM
cornbread2's Avatar
Where EXACTLY is this socket?
Old Nov 2, 2005 | 10:21 AM
dczys's Avatar
its deap down inside the center of the clutchperhaps inside the crank? but its far down in there
Old Nov 2, 2005 | 01:08 PM
Bradracer18's Avatar
He dropped it in the hole that goes into the motor behind the clutch, by the sounds of it.......I guess I was never sure where that hole went to.......
Definately remove the clutch......you will need a puller......
Old Nov 2, 2005 | 02:11 PM
dczys's Avatar
the puller will be pushing on that socket that goes into the hole just pushing it further inside, i really dont think a puller is going to help in this situation?
Old Nov 2, 2005 | 02:25 PM
What?? The puller goes into the hole in the center of the clutch that goes in towards the motor..........is the socket in there???? If not, then remove the clutch.......
If so, wow......uh.......I guess see if a powerful magnet will take it out.....or a screwdriver with a hook on it......or a pick ......
Old Nov 2, 2005 | 04:33 PM
dczys's Avatar
I GOT IT!!!,, drove a 3/4 inch bolt in tight real tight,, and tapped the clutch with a hammer and it popped off! but theres still a lil chunk of socket stuck in the crank,, i was thinking to drill it out some then screw a bolt into that to back it out? what u think? any ideas,, also i broke a small chunk of the sheave,, how could that be repaired?
Old Nov 2, 2005 | 06:01 PM
No one is for sure where you are talking about......be very specific..........where did you break a chunk off of?? Also, what did you use the bolt for??
Old Nov 2, 2005 | 06:36 PM
dczys's Avatar
the chunk broke off the top corner of the sheave engine side.. its about the size of a quater..
