PRED 500 JETTING
Old Nov 2, 2005 | 08:16 PM
TNTINSURANCE's Avatar
Default PRED 500 JETTING
I have an 05 500 and just ordered a Yosh full system and K&N snorkel air filter system to replace the lid and stock flat filter set up. Stock jet is a 150. Any recommendations on what I should jet up to. Use is just about always at sea level. I was told 165 to 170? Also, I have heard that I have to adjust the needle to the 4th position and then also adjust the fuel / air screw?
Thanks in advance.
- Walt
Old Nov 3, 2005 | 05:13 PM
heatseeker8's Avatar
165 seems a bit high....
With a k&n drop in and a Yoshi slip on at 1100' I didnt need to rejet at all.
Old Nov 3, 2005 | 05:40 PM
hudson4269's Avatar
At 150 jet I am running SUPER lean at 1000 ft elevation and around 80 degrees.
Im going to a 160 and everything is stock so I would say start at 165 to 170 and go up.
Old Nov 4, 2005 | 09:11 AM
Wow..never heard of that before..My plug is mint and I've always heard Pred's were jetted rich. I'm also at 1000' feet.
Old Nov 4, 2005 | 04:07 PM
XShowtimeX's Avatar
I'm at 1100ft with a 155mj, you see my mods and I'm a bit rich as heatseeker says Preds are rich from the factory.
ReconBayou
Oct 31, 2022 05:37 PM
BYC
Sep 25, 2015 02:10 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
