custom intake tube made for mojave??
Old Nov 2, 2005 | 09:10 PM
mojo21's Avatar
Default custom intake tube made for mojave??
Hey, just wanted to know if i could make a intake tube for my mojave. I thought about using a dirtbike tube (a good section) to fit around the end of the carb, clamp that then use like an inch and a half or 2' or bigger pvc pipe with a slight bend to put it back by the rear of the quad. Then simply clamp a uni on the pvc pipe. I was thinking about buying cwr intake tube but if i could make it why buy it. any help will be appreciated.
Old Nov 3, 2005 | 12:35 AM
greenP650's Avatar
I have mine made out of a mandrel bent 90 degree exhaust pipe and have a radiator hose connecting the carb and an uni filter. It made me go up a main jet size after installing it.
Old Nov 3, 2005 | 07:15 AM
holeshotz8436's Avatar
it shouldnt be too hard. just get a 1 1/2 inch to 2 inch rubber boot adaptor that you could champ on to the 2 inch pvc and to the back of the carb, then cut the pvc a little before the rear shock and then use some 30 or 90 degree adaptors to work your way around the shock, then just stick a uni pod clamp-on on the back with a outerwear and you should be good to go. all the stuff (besides the filter) can be bought at a local hardware store and probally wont cost any more then 10 bucks and you could get the filter at rocky mountain or dennis kirk. o and when your done paint it black so it looks cool lol
Old Nov 3, 2005 | 08:22 PM
mojo21's Avatar
Thanks for the help, i have the pvc except the bend so it shouldnt be too bad, im just worried about jetting the thing, I have bad luck with carbs. lol
Customer Service #1
May 15, 2020 08:46 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Alex G.
Sep 19, 2015 06:34 PM
carid
Sep 14, 2015 03:40 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
