Is it worth doing??
Old Nov 3, 2005 | 12:18 PM
rodnreel's Avatar
Default Is it worth doing??
I'm considering adding wheel spacers on all 4, and lowering brackets to front of my Raptor. Would that better the handleing characteristics, or perhaps cause a different type of handleing problem?
I can't quite justify spending the cash to do it the right way (shocks, a-arms). I consider myself a good rider (of course), better than average, and less than expert. I like to ride trails, tracks, and fire roads. I enjoy the jumps, but am getting a little old for going after the Big Air. :-(
Is it worth the money to do these mod's, and will it make signifigant difference?
Thanks for the advice.
Old Nov 3, 2005 | 12:39 PM
LivinInVegas's Avatar
Yes it will work better because you are lowering your center of gravity and widening it for better stability. Although these parts are not intended for use in making "H-Bomb" videos as the shocks (Elkas, axis, PEP) are geared for hard core abuse, not the stocker. Without a decent shock and airing it out could prove the shock and your lowering bracket unreliable. Since you are not going to be doing this, I think you are fine. I would talk to someone who has them or see if they can put you in-touch with a tech-rep, to answer any questions that may concern you. But for your riding style I think your safe.
Old Nov 3, 2005 | 12:40 PM
Also if you end up with these, I would check the bolts after every ride in the beginning.
kodiacrunner
Oct 4, 2015 11:52 AM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
