long travel to short travel suspension.(lowering Scrambler)
Old Nov 3, 2005 | 12:53 PM
conig's Avatar
Default long travel to short travel suspension.(Scrambler)
I have a question my 2002 scrambler 400 is the long travel model. Presntly I have a set of progressive suspension front springs and adjusters and the stock sachs shocks. I would like to lower my scrambler some and I see by removing the front adjusters that came with the progressive suspension springs that I can drop the front 1.5 inches. I have been told and from what I can tell the spring adjusters do nothing on them.
I was also thinking I should pick up a set of Fox struts in the 6.7 inch travel model to match(good price). That way I won;t have to rig up any kind of limiting strap( when I remove the adjusters and the supension is at full droop) and since the fox shocks are better then the stock poop I will make more effective use of that travel to disipate shock travel. does this make sence? I have a chance to get some foxes for like 50.00 but I may need to rebuild them they are off a magnum.
just fishing for some opinions but I would like to pick these shocks up today to try it over the weekend prior to rebuilding but its a no refund scenario so I figured I would ask.
Old Nov 3, 2005 | 05:08 PM
conig's Avatar
TTT
Old Nov 3, 2005 | 07:41 PM
WIscrambler's Avatar
Default long travel to short travel suspension.(lowering Scrambler)
I've been wondering...what is it in the suspension that changes it from the short travel to the longer travel? Also, I assume the Fox struts were added to the Magnum. They never came equipped with Fox struts, did they?
Old Nov 4, 2005 | 12:27 PM
conig's Avatar
no they didn;t come equiped with them from the factory. The scrambler long travel suspension is 8.2 inches of travel via longer struts and 14.1 inch springs verses I beleive 11.6 but I'm not positive.
with the above idea I would loose travel but I would be soaking the bumps up more effectively and I want my front end lower anyway so either long or short travel struts I would still only get 6.7 inches.
Jul 21, 2015 03:03 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
musselmark
Jul 17, 2015 02:40 PM
maxjung
Jul 13, 2015 05:11 PM
Jkfx400P
Jul 6, 2015 10:04 AM
