WARRIOR OMG
Old Nov 3, 2005 | 07:23 PM
paintballbanshee's Avatar
Default WARRIOR OMG
guys give me a break please answer me... My warrior wont run.. it was fne, i checked the spark, fine, checked if it gettin gas, yes it is, but, when i turn the key on the lights wont turn on, just the nuetral light, and now it wont crank, i am charging the battery, but it still is like dead, i think theres something run with my electrical but i dont know what to do, and im going riding for the weekend, im so mad i just want a quad that will run when i need it..
secondly, my friend has stock predator front and rear shocks that he gave me, can i and should i install them on my warrior?
Old Nov 3, 2005 | 07:39 PM
Default WARRIOR OMG
BUMP!!
Old Nov 3, 2005 | 07:40 PM
warriorguy22's Avatar
Default WARRIOR OMG
could be the stator, that is what went wrong with my warrior.
Old Nov 3, 2005 | 08:02 PM
95wolv's Avatar
Default WARRIOR OMG
Have you checked the fuse under the seat near the positive cable junction, that could prevent the starter from going, and may be the reason the lights don't work.
Old Nov 3, 2005 | 08:19 PM
DriverDoyle's Avatar
Default WARRIOR OMG
Man i fill for you wireing sucks it could be anything one little wire or a fuse there is no telling were to start
Old Nov 3, 2005 | 09:23 PM
400EXGuy070's Avatar
Default WARRIOR OMG
my warrior will shift through all the gears, but it revs really high but goes really slow... its speed is normal through 1st and reverse but when i shift it only lets my go a little faster...could it be the clutch?
Old Nov 4, 2005 | 01:21 AM
outkastjoe's Avatar
Default WARRIOR OMG
Have you made sure it is not the battery. Have you tried jump starting it of another machine? My battery died once and no matter what I did I could not bring it back to life.
Old Nov 4, 2005 | 03:18 AM
DeathShadow's Avatar
Default WARRIOR OMG
http://www.yfm350central.com
Old Nov 4, 2005 | 12:49 PM
jaggers2e42's Avatar
Default WARRIOR OMG
sometimes a battry can be so dead that it will not take charge no matter what you do.take the battery out of a buddies quad and just give it a try.
Old Nov 4, 2005 | 01:56 PM
Air's Avatar
Air
Default WARRIOR OMG
Battery is shorted internally.
