Changing Brute Force coolant
Old Nov 5, 2005 | 12:52 PM
JPBabyRange47's Avatar
Default Changing Brute Force coolant
I'm in the process of changing the coolant on my Brute to Engine Ice- does anyone have a step by step to this- where is the drain plug?
Old Aug 9, 2021 | 09:16 PM
Atvmechanik's Avatar
it is behind the coolant reservoir remove the five screws holding reservoir and the top hose from the reservoir and lay it over to the side then locate the water pump housing the bottom middle 8mm in the water pump housing is the drain bolt for the coolant
utekcnc
May 22, 2019 12:17 PM
danielaep
Jan 8, 2009 01:53 PM
Supertone
Apr 29, 2007 11:33 AM
sandpit
Mar 23, 2006 01:50 AM
DSaholic
Aug 8, 2002 07:50 PM
