Sportsman 500 no power! Help!
Old Nov 5, 2005 | 08:11 PM
BigggT's Avatar
Default Sportsman 500 no power! Help!
I have a 96 Sportsman 500 -will idle fine just has no power . Bought it used, never seemed like really had that much power always lost it on the topend, or just going up hills etc, but got worse. So at first thought must be carb! so took apart cleaned it (many times), diaphram was marginal so replaced it, fuel filter replaced checked all vent hoses air box for leaks etc took fuel pump apart there was plenty of dirt on the vent side cleaned it, thought that must be the problem, but made no diference. tried another carb off another machine ran the same! so since then!
1) tore it down checked exhaust lobe was within .001 of new dimensions, rocker arm looked good no unusual wear.
2) pulled the black wire off limiter like u suggested above no diference.
3) made sure elc throttle control was not causing problem.
4) tried pushing reverse bypass switch while acceelratings no diference
5) tried putting on choke while accelerating, wanted to die then.
6) sprayed carb cleaner around carb while running checking for leaks no diference.
7) ran fuel with a direct line from gas tank to carb by-passing fuel pump made no diference.
Anybody else have any other ideas please tell me!
Old Nov 5, 2005 | 08:43 PM
Jayblazer's Avatar
it just sounds like the cam but you checked the exhaust lobe.??? i would check the cam again..if that dont work try the stealership route
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
tweeder
Jul 5, 2015 01:57 PM
