Polaris Newbie-On demand 4X4?
Well, I bought a used 2000 325 4X4 Magnum. I was just reading the manual and it has on demand 4X4? I figured if I switched it to 4X4 it would be so until I switched it back. Does this system work- suppose to sense rear tire slippage and lock in front wheels? Is it dependable and what is the advantage and/or disadvantage to true all time 4X4. Does it work well for snow plowing? Do they still use it on their new bikes? Thanks- as I am slightly uneasy about this elctronically controlled 4X4 system.
Good! system.. you need to keep the front hub oil changed whenever it gets a little dirty or it might cause some problems with not comeing out of awd. you can use synthictic ATF that works well...some on here might prefer or sugguest a different oil. if your not sure about what to use just get the polaris stuff.
Be a good idea to change it now so you know it's clean no water or dirt in it. along with the rest of the fliuds.
Jeff
Jeff
Still slightly confused and I have now read through all the other posts about the AWD system. I don't seem to have an indicator light so I am not sure how I will know if it is engaging, disengaging and working correctly. If I have rear slippage and then twenty feet later it stabilizes is is going to pop back into two wheel drive? Then if I hit another slick spot another twenty feet back into 4 wheel and back and forth? Seems like a system setup to fail especially since you are relying on electronics. What is the life expectancy of a system like this?
its the best system the rear slipage is like 1/8 inch and the fronts grab its the best because you can drive with it on and not even know it, it doesnt affect performance it just switches on and off as needed..
its the only 4wd system i have ridden on quads that dont affect the stering of the quad. It does work great but requires more maintenance. the hub fluid is only 8 bucks and its real easy to change. I still like a locking differential better when going through real thick stuff but locking diffs make it real hard to steer.
OK. That sounds more reliable and it seemed to work today. I hear the hub fluid needs to be replaced periodically to allow the front hubs to disengage correctly. The manual said to turn the hubs to 4 o'clock position and remove set screw to see if fluid comes out or needs to be added. I would suspect you guys are talking about turning the hub around so all the fluid drains out of the hub and then back to to 4 o'clock and refill until it starts to run out hole?
One more stupid question. Where is the best place to jack up this beast so you don't mess with the strut system? I figure a nice block of wood between your jack and the front belly center to lift the whole front end up at once?
