04 grizzly radiator
Old Nov 6, 2005 | 09:10 PM
put's Avatar
put
Default 04 grizzly radiator
does any one have any problems with their griz getting hot and the light coming on - today on a ride my ride partner has the same machine and his light never came on while mine was on frequently- radiator looks clean but i may need to remove it and do a thorough cleaning - any help?
Old Nov 7, 2005 | 03:24 AM
Starky's Avatar
What type of riding were you doing. Did you check your coolant. It could be an electrical problem.
Old Nov 7, 2005 | 03:48 PM
Curls's Avatar
I have an 04 Griz and the light came on because the thermal switch was bad. There are two thermal switches one is up by the radiator and it turns your fan one. The second activates your overtemp light. It will cost about $30.00 and 15 minutes to change. The switch is located by your head and is easy enough to get to. If there are no other signs of your Grizz getting hot then it probably isn't and it will just be the switch that has gone bad. They are very fragile, do not drop or mishandle your new one.
Old Nov 8, 2005 | 04:58 AM
Starky's Avatar
I highly reccomend puting Engine Ice in place of your coolant. I use my Grizzly, actually my wifes Grizzly, to pull a disc and use the Swisher plow and bucket to clean up after the horses. The light used to come on because that is just a lot of work on the engine. Since I put Engine Ice in it the light doesn't come on any more. I wish i had a temp guage to see what the differance really is.
Old Nov 8, 2005 | 03:07 PM
put's Avatar
put
thanks for the info - i'm just about to start taking the radiator out and i'll look into the engine ice
Old Nov 8, 2005 | 08:18 PM
Curls's Avatar
Don't take the radiator out. It is completely unnecessary. The thermal switch that controls the overtemp light is on the head. Follow the two little wires that looks like a bolt. I think it's a 12mm wrench that used to unscrew it. I have talked to a number of people on this forum with the exact same problem and it has always been the #1 thermal switch.
Old Nov 8, 2005 | 09:07 PM
Ljay's Avatar
Whats engine ice? I'm assuming its a new type of coolant? is it green, or like the newer **** yellow stuff?
Old Nov 9, 2005 | 01:37 AM
Starky's Avatar
Engine Ice has been around for about 6 years I think. I can't remember what color it is though. I think it's red or purple. You use it straight and do not add water to it. It really does lower the temp of your motor. A guy on the Grizzly Owners Forum had just installed a temp guage on his Griz and was going to switch to EI but my server blocked that forum and I don't know how much it actually lowered the temp.
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
