Bent my 250R subframe now what?
I took this stepup but the takeoff ended up being to small and I flipped. My thumb throttle broke right off and bent my grab bar. I thought that was it, I got pulled back and looked closer at it and saw I bent my tie rod, then I took off the rear plastic and saw my sub frame was bent. Standing behjing you can notice the right side it a little to the left and down. Is there any way to straighten it or should I just add bent sub frame to my signature? Please help...
I would try Precision ATV and see what they say they may put a new sub frame on. there number is 1-866-ATV-PART or Take it to a bike shop and see if they could straiten it
Here's an idea but I actually don't know how well it would work. I've been concerned with the very problem(on mine it hasn't happened yet). I think that if I were you, I would buy an Arens SUBFRAME, have a fabricator cut your old subframe off and weld new tabs for the Arens subframe to bolt to. This would probably be your cheapest option. You would have to make sure the tabs were located in the correct place! Just an IDEA...
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
