eton 50 not running right
Old Nov 9, 2005 | 08:03 PM
Jayblazer's Avatar
Default eton 50 not running right
This quad only has about 3-4 hours on it, it’s a 2005 ETON viper 50 2-stroke
it will idle fine but does not have enough power to move itself . It first happened when my niece was trying to climb a small hill all of the sudden it started acting like it fouled a plug so I put it until I was able to get a new plug today I put in the new plug (the old one was black and wet with fuel) and it did not act any differently It still acts like it has a fouled plug and adjusting the throttle limiter does nothing it runs the same at 1 as 7.....
Please help....
Old Nov 10, 2005 | 12:03 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Check the gas. Check and clean the spark arrestor if it has one. Check for kinks in the fuel lines. Replace that cheap fuel filter.
Old Nov 10, 2005 | 09:14 PM
Jayblazer's Avatar
it s running alot stronger now i changed the gas and cleaned the carb but u dont think the cdi is working right. do you know a way to test it???
Old Nov 11, 2005 | 07:35 PM
kawieman700's Avatar
If it's set on the highest setting take the spark arrester out and you should be good to go.
Old Nov 11, 2005 | 09:07 PM
DirtDragon's Avatar
Take the CDI out of the sleeve and cut the looped wire on the back. I think it is green. You will not believe the difference.
Old Nov 12, 2005 | 08:30 AM
Jayblazer's Avatar
will this make the quad run faster?? because im not ready for that these are still little kids riding..
Old Nov 12, 2005 | 08:00 PM
Blazer there is no green wire on your 2005 50cc it has a adj. cdi box settings are 0-7 the cdi box is located in the frt. of the bike take the frt. nose cone off and i think it's on the r.h.s you cant miss it a rubber gromet is holding it on it's a black box.
Old Nov 12, 2005 | 10:21 PM
Jayblazer's Avatar
yea i got that but it runs the same at 1 as it does at 7 i dident use to be like that[img]i/expressions/face-icon-small-sad.gif[/img]
Old Nov 13, 2005 | 10:24 PM
oldyeller's Avatar
I agree with Raptorlegs its probably the spark arrestor.They seem to plug up very easily on the 05 models and will kill all of your power.
Old Nov 13, 2005 | 11:24 PM
Jayblazer's Avatar
well today i had it running and oil/gas started running out the exhaust so what do you suggest i do?
should i just pull out the spark arestor completly? or just clean it out and put it back in. i dont think i need it they just ride it around the ranch. but if i take it out will it run lean?
