mounting supertrapp on mojave
Old Nov 10, 2005 | 12:33 AM
moonraker's Avatar
Default mounting supertrapp on mojave
I have a stock 96 mojave and mounted a used supertrapp IDS2 race series [supetrapp header included ] and expansion chamber is hitting frame. I have loosened the clamp between the muffler and chamber so I could rotate everything as I was mounting it but it still hits the frame. Also how many disc for riding in the midwest and power at low and mid range? Thanks.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 10, 2005 | 07:22 PM
rolsmojave3's Avatar
yeah i have the problem with it hitting...i bent the head pipe so it'd be a little farther away and that helped....also i run 7-9 discs for midrange
Old Nov 10, 2005 | 10:30 PM
moonraker's Avatar
Thanks for the info at least I know it's not something I'm doing and I will try a few more disc and see where the most power is. As of right now it has really woke it up on low end power.
Old Nov 10, 2005 | 11:06 PM
NEWDUCK's Avatar
Do you have the quite core or the race core?
Old Nov 10, 2005 | 11:15 PM
moonraker's Avatar
I have a race core but it is really not that loud with 4 disc in it and a spark arrestor on the end. I do get a miss in it when running wide open and the miss is at the top end but I'm not sure if it"s jetting or hitting the rev limiter. I backed out the pilot air screw 3 turns to get it to idle and not stumble on take off.
Old Nov 10, 2005 | 11:24 PM
NEWDUCK's Avatar
If you ever want a quite core for some reason ill trade you straight across for your race core. I would say your main jet is a little lean if you are missing on the top end and wide open.
Old Nov 14, 2005 | 07:40 PM
moonraker's Avatar
Thanks for the offer but for now I'm going to try this one. I'm really surprised with the power found in that little engine with just a pipe. My freind has a 93 warrior that is in stock condition and when we would drag race before I would get the hole shot for about 50 ft. then he would blow by meand win by al least 6 atv lengths. Now I'm beating him by 2 atv lengths and still waxing him on the start and I out weigh him by 50 lbs. He can't beleive the difference either with just a pipe and no jetting.[img]i/expressions/face-icon-small-smile.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
Alex G.
Sep 19, 2015 06:34 PM
chewy78
Sep 8, 2015 10:37 AM
toonces
Sep 5, 2015 01:14 PM
