Oil pump block off for LT80
Old Nov 14, 2005 | 12:21 AM
maggiesboy's Avatar
"One Wheel Short"
Default Oil pump block off for LT80
What are people using to block off the injector. I plan on running 40:1 for mix ratio. Any thoughts?
Old Nov 14, 2005 | 05:11 AM
Quad4Fun's Avatar
Hey MB....
You can pull the little deelie bob off the front clutch that turns the pump.
Then you can pull the pump off and make your own cover for the hole.
Then I took the plug that goes into the carb and cut the hose off of it,
filled that up and put the plug back in.
Works good and is cheaper than buying the block off kit.
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
