where do you buy LT 50 main jets?
Old Nov 16, 2005 | 10:48 PM
adamcarp's Avatar
Default where do you buy LT 50 main jets?
where are you guys that are pumping up your LT-A50's buying your main jets for carb at?
my local dealer can't get them from suzuki or aftermarket. aren't they just mikuni jets?
does anyone have part #s for a 67 and 70 size jet. and where did you get them?
thanks adam
Old Nov 17, 2005 | 11:25 AM
4CooperRacing's Avatar
I am not sure of the carb used on the LT but you should be able to find the jets you need at www.sudco.com
There is a minimum order.
Old Nov 17, 2005 | 12:05 PM
Dirtmomma's Avatar
testing testing 123.
Take the jets to your local shop & have them look!!
Old Nov 17, 2005 | 01:22 PM
Familyofthedirt's Avatar
I feel your pain. My local dealer is useless. I have a couple of independant shops locally that have a good selection of mikuni jets. You might try that route. If no local shop you could also call CTRacing. The have Boxes of them. Good luck
Old Nov 17, 2005 | 05:46 PM
MrSandman's Avatar
Most dealers, aftermarket or OEM don't stock the smaller sizes because they don't move. The Mikuni part number you want is KN102.221. These jets come in full sizes, 40, 45, 50, 55, 60, 65, 70, 75, 80, 85 etc., etc., and half sizes 67.5, 72.5, etc. The number represents millimeters so a size 70 would be a .70mm. If your dealer is worth a salt, he can order what you need from Mikuni or Sudco. Or you can get metric drill bits and drill out the stock one until you get it right, but there's no going back once you start drilling.
Old Nov 17, 2005 | 06:10 PM
Actually you can solder the hole and re-drill if you need to go back smalller.
Old Nov 17, 2005 | 06:22 PM
maggiesboy's Avatar
"One Wheel Short"
Your local "quality parts house" should be able to dial you in, on the spot.
Old Nov 23, 2005 | 07:24 PM
MrSandman's Avatar
Here you go in case you haven't found the jets you were looking for.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Brandon400
Sep 5, 2015 08:44 PM
