lakota supertrapp(jet size ??)
Old Nov 17, 2005 | 08:43 PM
tmaxx's Avatar
Default lakota supertrapp(jet size ??)
i put a supertrapp ids2 quiet series exhaust on my cousins lakota today. it has most of the mods mine has except the clutch plates and srings. i put in the 138 jet and used all the discs, but it ran to rich. if i put in the 134 jet how many discs should i use, or shouldnt i drop to the 134?
oh ya and his headpipe is leaking with the new pipe(right where it bolts to the head) is there anything i can seal this up with besides ordering a new gasket? atleast until a new gasket comes? like high heat liquid gasket?
thanks
Old Nov 17, 2005 | 10:14 PM
holeshotz8436's Avatar
for jetts a 134 might be too small dependingon how rich its running, although they are hard to find try to get your hands on a 136. You might also need to get a smaller pilot jet and ajust the needle a bit. It will take alot of playing around with it to get the jetting right on. As far as the head pipe leaking use some non silacone gasket sealer/maker(the black kind) and it will seal it right up or you could get a new one of those crunch gaskets at many hardware stores or a autozone or napa.
Old Nov 17, 2005 | 11:44 PM
tmaxx's Avatar
i was just wondering, if he bought another set of discs and used like 18 would that lean it out enough to use the 138? because it was a little rich with 12 discs
Old Nov 18, 2005 | 09:04 AM
i would only use the discs that it came with because thats what was ment to be used so it looks like you need to change the jetts
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
