1998 AC454 - Front axle
Old Nov 20, 2005 | 01:40 AM
Andy Bassham's Avatar
Default 1998 AC454 - Front axle
If I'm right, the front axles (half shafts or whatever you want to call them) are supposed to just pop out of the differential correct? I got the left side out, but can't get the right side out for the life of me. I'm needing to replace a few seals in the differential, and I need this thing out of there. Is there anything I'm missing?
Old Nov 20, 2005 | 02:41 PM
Bear4570's Avatar
Maybe it has been replaced in the past and has the retaining clip style on that side?
Old Nov 22, 2005 | 02:18 PM
billyjoejimbob's Avatar
It should just pop out. You may have to put a pry bar of sorts inbetween the joint and the diff. Just be carful because the diff is more than likely alumminum. Try turning the joint in a different position.
Old Nov 23, 2005 | 10:18 AM
TORK's Avatar
It will pop out. Some of them can be a real bear to get out. Arctic Cat has an adapter to fit on to a slide hammer that fits around backside of axle. If you could get a picture of it I think you could build one pretty easy.
toonces
Jul 28, 2015 01:58 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
Rider252
Jul 6, 2015 03:37 PM
