Eton 70 viper carb adjustment
Old Nov 20, 2005 | 07:26 PM
cvc42's Avatar
Default Eton 70 viper carb adjustment
I have a new 70 viper that has just finished the first tank of pre mixed gas. It still smokes a little would adjusting the lean screw fix that and how can you tell on a 2 stoke when you have carb right.
Thanks
Old Nov 21, 2005 | 10:01 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Excessive smoke can be caused by two things. Incorrect jetting or incorrect oil ratio. You pilot can be adjusted by the mixture screw, but this doesn't help your needle or main jet. If you aren't having a problem with fouling plugs, I'd leave it alone until you're rady to tear into the carb and go pre-mix.
Old Nov 21, 2005 | 08:53 PM
Randes's Avatar
I have a 70 and it smokes a little until gets warmed up. I wouldn't worry about it
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Jun 16, 2016 09:07 PM
micheleLeigh
Jul 12, 2015 02:50 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
